Hello,
I recently finished my first build, and I am having some trouble getting it to work. Please forgive me if this is actually a common error: I tried my best to research it beforehand, but my knowledge is somewhat limited in the advanced settings of a PC.
I have been trying out a couple of games on it, ie Skyrim and the original Assassin's Creed. They both have this problem where the computer will freeze entirely, as in it will remain on and the screen will not turn off, but the screen will not update, it does not respond to any input, and no sound comes from the speakers.
I have been trying to look for a solution, but most of the situations I find online are not the same. It seems that most people have the game crash to the desktop, but the computer is still running fine. Mine completely freezes up and I have to cut off the power manually to turn it off.
The worst part is, I cannot find any abnormalities in the functioning of the PC. It will crash at random moments in the game, not particularly active ones or anything. I thought the graphics card might be overheated, but it was at most at 67 degrees Celsius when I last played. Other than that, when the screen last froze up, it showed my CPU at only 22% usage, GPU at 40%, with about 10% of memory used (both RAM and VRAM). My system specs are below:
CPU: Intel i7-3820 @ 3.6 GHz (stock clock)
RAM: 16GB (4x4GB) Corsair Vengeance @1333MHz
Mobo: Asrock Extreme4 X79
Storage: 128GB Crucial M4 SSD
GPU: Zotac GTX 680 2GB (stock clocks)
PSU: Seasonic Platinum 860W
I can give any more info if needed. Thanks in advance for any help!
