Question Computer repair gone wrong running out of ideas
Aug 4, 2024
13
I recently started a small business in computer and electronic repair, but the computer I’m working on currently has stumped me, it was running perfectly fine until someone swapped the power supply in it, and then it suddenly started constantly boot looping, I replaced the power supply, motherboard, ram, cpu, and even tested different ram sticks, and gpu’s I had lying around, at this point the only thing I haven’t tried is taking the parts and putting them in a different case, the pc no longer boot loops but will now restart three times, turn on a fourth time, but that’s it, no display, no beeping, nothing. I am at a loss on this one and have already had my client waiting for so long and the parts keep racking up the bill, does anyone have any suggestions or should I just call this one a loss and buy a new rig save for the pieces I already have.?
The pc specs are
I5 6500 cpu, gtx 1650, thermaltake 500wpsu, 16gb of ram
The motherboard was an asrock170 but I had to go with a generic board off Amazon, the Bewinner lga1151 motherboard, anything name brand was outside of the customers price range, I tried disconnecting everything from the board, all drives, gpu, even single ram in both slots swapping between different sticks, my best guess was gonna be trying to flash the bios via usb to see if that would fix my issue, but the generic board makes it difficult to figure out what bios files to use
Do you have a link to this Bewinner lga1151 board?
For example this monstrosity https://www.amazon.com.be/-/en/Bewinner-Motherboard-Supports-Generation-LGA1151/dp/B0CFYGH14W
It describes 8th/9th gen support and Ivy Bridge but Ivy Bridge socket is 1155. Load of rubbish that is. Curious what this board claims to support and what it actually supports.
When your client swapped power supplies, was the original psu semi or fully modular? If that were the case, hope they replace the cables, bad outcome if didn't and mixed them. I really wonder what they did, might help shed some light on the matter and ideas moving forward.
What were the original components? Many things have been swapped out, it's hard to get sense of what's going on.
The old power supply was a generic Chinese unmodular 1000w power supply, the original cpu was the same i5 6500 and the one you posted is the right one, should I return it and order a second hand board off eBay?
This might help find a board, if you can buy from Newegg. Or as reference to search elsewhere. I've filtered to include 100 and 200 series, various chipsets from Asus Asrock Msi and Gigabyte.
https://www.newegg.com/p/pl?storeId...600567581+50001944+50001315+50001314+50001312
I managed to find a second-hand Asrock board almost the exact same one that he originally had, hopefully, this works, I really am starting to second-guess myself, never thought a computer could cause so many issues
Id still like to know what they did. Replaced psu, ok, but how was that done and what else did they do. Seems they didn't tell you the whole story. If something is harder than it should be usually means something else is up.
Good luck, let us know how you go.
Yea I’m not too sure either, all I was told was that the PSU got taken out and put back in and then it would just boot loop over and over again, there’s about 6 kids in the house and the case is missing a USB-port so it's definitely seen better days, my best guess is he wasn't careful taking out the power supply and damaged something or maybe fried the old board, I did notice some one or two bent pins under the cpu for the old board, but I don’t think he would have gone under there
And in post # 3 you also said you removed the drives. The only thing left is the case. You said it is missing a USB port so maybe that's where the owners issues started.
The last person to jam a USB device into the now missing port could have fries the USB port and that carried over to the motherboard.
But unless you grabbed the front header wiring and hooked it up to the new motherboard not thinking about it to that missing USB port " if it was still in the case" you could have replayed the original default issue leading to the new parts acting just like the old parts.
Unless already said build the new parts out of case on the table to just remove anything from the owners original build that you don't have to use. See if you get life.
Yea I tried hooking everything up outside of the case to no avail, literally everything but the GPU is new at this point, and the case, but I didn't even use the case when setting it up the second time just to be safe, the computer now just boots, doesn't even get into the bios, I was thinking maybe flashing the bios would help the issue so that’s the next thing on my to-do list
Pins don't bend themselves so who knows. Sometimes can get lucky with bent pins and computer would still run, never knowing until someone looks. Highly unlikely though. I feel sorry for you lol
So I got the actual motherboard in, but installing all of the working parts onto the new board, doesn’t give the boot looping issue anymore, now it just boots with no screen, input, or anything
What's the latest specs of this pc?
And the cpu with bent pins is out of the question?
The motherboard itself had the bent pins when the machine first came in to me, the original specs were
AsRock z170A
I5-6500
Gtx 1660
16 gb SK Hynix ddr4 ram
R88 power ac bell 700w psu
The parts are now
AsRock H370M
I5-6500 (New)
Gtx 1660 (Same)
16gb Gigastone DDR4
Thermaltake 500w PSU
I tried all the new parts outside of the case first, and tried all of the different ddr4 ram I have including the working ran from my computer, could the motherboard be another dud?
AsRock z170A
I5-6500
Gtx 1660
The parts are now
AsRock H370M
I5-6500 (New)
Gtx 1660 (Same)
16gb Gigastone DDR4
300 series is 8th/9th gen, 6 series won't work on it.
Okay grabbing a straws here. Change the HDMI cable, use different monitor. Switch in different mouse and keyboard. Fingers crossed for you :)
I was using my tv to test out the bench funnily enough I know the gpu is definitely putting out power because my tv will say “HDMI connected” but give no signal, I’m gonna try and hook it up to my monitor and see if I get a different result, worst case I keep returning stuff to amazon until something works again and hope I don’t get flagged
Yeah that's right. 100/200 series for 6th to 7th gen - these are cross compatible, then 300 for 8th/9th. Same socket and amount of pins but are arranged differently.
Bought a 9th Gen Intel cpu because they seem to be at that sweet spot in Canada where they aren’t overpriced or rare because of the age, but also old enough so I’m not paying a new premium price, hopefully this works now
