Computer Starts with - Signal Not Found on Monitor
jackhammer1
8
Installed a new cpu fan as the last one was not working [from age]
tryed removing the gpu - switching monitors. silly mistake through all of this
was working on the carpet. the machine does start up just nothing comes on the monitor what can this problem be ?
so far my solution has been putting it aside and calling it a day with a fried motherboard.
many thanks for your help
If it says signal not found it could be a gpu issue "which could be less likely" or it could simply be the cable. I would try switching the cable before opting for a new gpu
If your mobo has an onboard vga/hdmi output i would try testing it out on that
clearfork4pk1ng
27
