Question Computer suddenly not responding. Desktop loads but then freezes. No signal to monitor.
Vickers
22
Switching to a different display port doesn't seem to be working either. I've done absolutely nothing different today that would cause this. At first I wondered if my mouse was broken which would explain no signal, but I tested it on another computer and it works fine. My only suspicion is perhaps my GPU is failing? If I use VNC viewer to remote in from my phone, I can login to Windows, however, after a certain point everything stops loading and it freezes indefinitely. Any ideas?? I really need this computer for work. 🙁
Now I'm having instances where I can't even view my login screen or desktop while remoting in. I'm at a loss..
10900k (stock)
32gb G.skill ram (stock)
Gtx 1060 (stock)
ASUS ROG STRIX Z490-G LGA 1200 micro ATX
Samsung 2TB 970evo Plus M. 2 (over 1.0 TB of space free)
Corsair SF750
Lian li o11 mini
I'd recommend trying to connect to your onboard graphics and bypass your card.
Have you checked to make sure that your graphics card is seated properly into the slot on your motherboard?
Sounds like your computer is working fine since you can remote into the system and login that way. You may be on the right track with your graphics card.
