heya naksimka;
Ok lets start reassembling, reinstall the CPU, make sure and use thermal paste, and that the HSF is on flatly and firmly. Next lets put in the memory, only one module, put it on slot 1, then put in the graphics card, and plug in the atx cable to the graphics card if it requires one, then connect the main power plug to the mobo, and also the square 4-pin ATX cable into the motherboard. Now from here the computer should power up, post, and get all the way to the point of booting the hard drive and realise there isnt one and stop.
Oh and yes some motherboards are set to protect mode from the factory, to clear it you need to reset C-Mos, you can usually do this by unplugging the power cord from the PSU, then pull out the battery, then replace the battery and plug it back in.
If this doesnt work tell me whats going on with it in detail.
<font color=blue> <Archer> Cant this thing go any faster, I thought this was a Warp 5 engine?
<Trip> Yeah, on Paper... </font color=blue>
