Approximate Purchase Date: Soon as possible
Budget Range: 1000 is ideal cut off point.
System Usage from Most to Least Important: Gaming
Are you buying a monitor: No
Do you need to buy OS: Yes
Preferred Website(s) for Parts: newegg.com
Location: City, State/Region, Country - USA, TN, Kingsport
Parts Preferences: I prefer Intel processors and Nvidia cards, but wouldn't mind a AMD card if it can hold its own.
Overclocking: maybe
SLI or Crossfire: maybe, but not likely
Your Monitor Resolution: 1366x768
Additional Comments: I just recently got out of the Army and I have been stalking newegg for years looking up gaming computers; its just not been something I could convince myself to spend that much money on. I would like to get back into PC gaming to play games like Witcher 3, Arma 3, and Star Citizen, all intensive type games.
I found this desktop on newegg iBUYPOWER Desktop PC VERSA SERIES NE403I Intel Core i7 4790K (4.0GHz) 8GB DDR3 1TB HDD Windows 8.1 64-Bit ( http://www.newegg.com/Product/Product.aspx?Item=N82E16883227602).
I believe I may just be ignorant though and be missing out on building something much better for cheaper. I would like around gtx980 level card because I would like this to last for a few years without worrying about needing to upgrade.
And Most Importantly, Why Are You Upgrading: Current computer is going the way of the buffalo.
Thank you guys for the help and input I really appreciate it.
Overclocking: maybe
