Confused on a power supply
pegasusking
52
I'm looking to change the GPU in my build to a 980 ti (classified ACX 2.0 REF 6GB GDDR5) from a Geforce GTX 960 SSC. Here is my build, PSU's are not my thing so I struggle in finding the right one. The right one being either a new one, or if mine is sufficient.
-AMD FX-8350
-2x4gb of 2400 mhz ram
-Gigabyte ATX Socket AM3+ mobo
-1x500gb 7200 rpm HDD
-1xSamsung SATA 1.5 Gb-s Optical Drive
-XFX TS Series 550W PSU
How could Nvidia make a 600W PSU recommendation without even knowing his system? ;)
It's perfectly fine. As can be seen, the 980Ti system here http://www.kitguru.net/components/graphic-cards/luke-hill/evga-gtx-980-ti-classified-acx-2-0-review/14/ is measured from the wall. Watercooler, overclocked to 4.4Ghz I7-5960X. Gaming load is measured 460W about from the wall. Looking at the Seasonic Platinum 1000W review...
It's perfectly fine. As can be seen, the 980Ti system here http://www.kitguru.net/components/graphic-cards/luke-hill/evga-gtx-980-ti-classified-acx-2-0-review/14/ is measured from the wall. Watercooler, overclocked to 4.4Ghz I7-5960X. Gaming load is measured 460W about from the wall. Looking at the Seasonic Platinum 1000W review http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story3&reid=264 <-- the PSU that was used, that should put his system consumption around 420W. And his hardware isn't as extreme, so it'll likely be less.
pegasusking
52
That is very noteworthy, I would also like to note that nothing is overclocked in my build
Without overclocking you'll be more than fine.
Rogue Leader
It's a trap!
Those ratings are always excessive and based upon people using junk PSUs. His whole system will barely hit 450w at full load. The PSU he has is more than fine.
