Hello:
My main 22" monitor failed today and I am left without a display for one of my seldom used PCs. I have a working ViewSonic VA1912wb LCD monitor hooked via DVI-D cable to an XP Media Center PC used mostly for a server to my living room tv. It also has an unused d-sub analog connection on the back. Is it ok or possible to hook my other computer (Vista Ultimate 64-bit) to this remaining connection? In the menu on the Viewsonic monitor there is an option to select input for either Digital or Analog. I am not sure if that means I can use both inputs and switch back and forth without harming the monitor. I am afraid that might have caused my other monitor to fail.....I had an HD cable box, a DVI-D PC and an Analog PC all hooked to that monitor and switched back and forth from one to the other and also sometimes watched HD cable tv in a picture-in-picture without problems.......until the LCD input quit working and all I get is "no signal" on DVI-D input. The other two inputs still work ok but now I have to either buy another monitor or switch to two PCs on the ViewSonic. Anyone know if it's always ok to connect two PCs to the same monitor if it has two inputs? I sure don't want to ruin another monitor! Sorry to ask such a dumb question!!
