Question Connect PC case built in RGB to motherboard
ChadEO
34
4
18,535
I have the Cougar MX331 Mesh-G case which comes with RGB strips in the front and I was wondering if it was possible to connect the RGB strips to the motherboard so I can control everything with Mystic Light. Has anyone done anything similar?
Sig space specs can and wil change over time, when that happens this thread and their relevant suggestions will end up renderreed moot to the end user in the same boat as you're i right now. It's why we ask folks to include their specs in the thread's body.
In your instance, please mention the make and model of your motherboard.
https://cougargaming.com/fileadmin/downloads/USERS_MANUAL/MX331_Mesh-G_usermanual.pdf
Looks to me like the RGB strip doesn't come with any form of manipulation, it's merely powered with SATA power. I would say no, unless you can show the RGB strips have a 3 or 4pin connector apart from the SATA power input.
