Hello everybody,
System:
Case: H500m
GPU: Asus Strix RTX 2080
CPU: Intel i9 9900k
MOBO: Asus Strix-e Z390 gaming
AIO: Coolermaster ML360R (not purchased yet because that's what this thread is about.)
Other Fans: MF120R (not purchased yet because I have questions regarding the connection.)
PSU: BeQuiet Straight Power 11 650W
So I am new to the PC building world
Since I like the whole ARGB stuff i wanted my PC to be as shiny / "rainbow-y" as possible.
I want to install 3x MF120R in the front replacing the 2x200mm ARGB fans.
I want to install another MF120R in the back replacing the non-RGB fan.
On top of that I want to install the ML360R as a AIO ARGB cooling solution which comes with another 3 ARGB fans. They should come with an rgb hub.
So my questions are:
4. If none of this will work, what is the best possible solution? Smaller AIO with less fans perhaps? Or should I simply not use Aura Sync and control everything with the coolermaster software?
Thank you
-pizula
Edit: Not sure if this actually belongs in the cooling section but since I am having question about case fans / aio and stuff I thought this might be correct.
System:
Case: H500m
CPU: Intel i9 9900k
- In total I have 7 ARGB fans. Is it possible to connect all of them to 1 RGB hub? (Via argb splitter etc.)
- If that's not possible can I connect both hubs in a row? Basically what I mean is can I connect one rgb hub to the other as an extension? The reason I am asking is because I want to sync everything via Aura sync but my MOBO only has one 5V_ARGB Header.
Thank you
-pizula
