Question connecting headphones to a monitor with no headphone jack?
Aug 1, 2019
7
i just got a monitor with VGA and HDMI ports but no audio jack, is there any way I can connect headphones to it? sorry if it's a stupid question, I'm new to PC building with no experience and I haven't built my PC yet.
If the monitor itself has speakers then there is a way... by opening the monitor and splicing into the existing cables that go to said speakers and purchasing a jack which you would solder the wires to, and if you are up to that task, then it's a simple matter of drilling a hole in the plastic case to attach the jack and make it all look professional.
However, lacking speakers and any sound path in your monitor, you are SOL
if I were to do that I'd break the monitor for sure, given my luck and skill. thank you, though!!
