[SOLVED] Connecting to Wifi BSOD
Mini 300M USB WiFi Wireless LAN 802.11 N/G/B Adapter Dongle
802.11n? Not even ac? I bet its USB 2 as well. Hope you didn't pay a lot.
Your wifi drivers are from 2015
May 28 2015 - netr28ux.sys - Ralink Wireless Adapter driver https://www.mediatek.com/ - you won't find any drivers here, I looked.
Ralink RT2870 series USB802.11n Wireless Adapter Driver
are you on win 10? I can't find anything newer than Win 7 for this. Any newer drivers are likely relabelled Win 7 drivers, might or might not work with win 10.
Hi, I ran the dump files through the debugger and got the following information: https://pastebin.com/NZQhCYN9
File information:080320-6906-01.dmp (Aug 3 2020 - 05:20:31)
Bugcheck:DRIVER_IRQL_NOT_LESS_OR_EQUAL (D1)
Driver warnings:*** WARNING: Unable to verify timestamp for klwfp.sys
Probably caused by:NETIO.SYS (Process: System)
Uptime:0 Day(s), 0 Hour(s), 02 Min(s), and 07 Sec(s)
File information:080320-6796-01.dmp (Aug 3 2020 - 05:38:19)
Uptime:0 Day(s), 0 Hour(s), 00 Min(s), and 42 Sec(s)
File information:080320-12609-01.dmp (Aug 3 2020 - 05:15:55)
Uptime:0 Day(s), 6 Hour(s), 03 Min(s), and 21 Sec(s)
BIOS info was not included in the dump file. This can sometimes mean an outdated BIOS is being used.
It appears as if Kaspersky crashed all 3 times. Temporarily remove it and use Windows Defender for the time being to see if that helps.
You may also want to update your network driver:
Jul 01 2019rt640x64.sysRealtek NICDRV 8169 PCIe GBE Family Controller driver https://www.realtek.com/en/
Upload additional dumps if you continue to crash.
This information can be used by others to help you. Someone else will post with more information. Please wait for additional answers. Good luck.
