Connection Between you and your modem is broken, Limited Connection Ethernet
Ephaan
So for about two weeks I have been having this problem, and I have tried nearly everything, using all of my free time for the past to weeks trying to solve it, this morning I bought a new usb to Ethernet adapter and everything worked fine, for about four hours then it went back to the same problem, please help.
Reinstall your network drivers on your device, reboot, see if it helps.
If it doesn't: change the LAN port on your router, see if it helps.
If it doesn't: try to use a new ethernet cable.
If that doesn't help: contact your ISP to give you a new router.
If that doesn't help: Perform the ritual of exorcism :)
None of this worked, but could it be my dhcp?
I would guess that the problem is the line in your powerline system (the actual in-wall cables). Can you connect your PC to your router directly with a ethernet cable just to be sure that your hardware is working fine?
Did That and the connection Was Still Lmited 🙁
