Connection to Monitor Help
ajh1979
161
Hi Guys,
What is the best format to connect my pc to my monitor for best picture quality as I have various ways of doing this so im confused as to what will give the best picture quality from my desktop pc. May as well add that im after the best picture quality for gaming and movies.
HDMI
DVI
VGA
Thanks
Use the DVI!
HDMI is also just fine if you're not using an extremely high res monitor. It can also send sound if you use built-in speakers in your monitor.
