Question Constant and random BSOD when using pc
Dec 12, 2021
Ive had this pc for quite a while and it likes to randomly blue screen. sometimes it will go a month without doing it once then do it multiple times in one day. I have the crash dump files here:
On Sun 12/12/2021 1:16:09 PM your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\121221-28062-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x3F72A0)
Bugcheck code: 0x50 (0xFFFF96F901A00010, 0x2, 0xFFFFF80749A6CF23, 0x2)
Error: PAGE_FAULT_IN_NONPAGED_AREA
file path: C:\WINDOWS\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that invalid system memory has been referenced.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\WINDOWS\MEMORY.DMP
This was probably caused by the following module: ntkrnlmp.exe (nt!memset+0x400EF)
On Sun 12/12/2021 12:25:01 PM your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\121221-17734-01.dmp
This was probably caused by the following module: dxgkrnl.sys (0xFFFFF8065166D51A)
Bugcheck code: 0x50 (0xFFFFEA08D4CC3820, 0x2, 0xFFFFF8065166D51A, 0x2)
file path: C:\WINDOWS\system32\drivers\dxgkrnl.sys
description: DirectX Graphics Kernel
The crash took place in a Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
On Sun 12/12/2021 12:13:44 PM your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\121221-12984-01.dmp
This was probably caused by the following module: ucx01000.sys (0xFFFFF8020E6C1612)
Bugcheck code: 0xD1 (0x0, 0x2, 0x1, 0xFFFFF8020E6C1612)
Error: DRIVER_IRQL_NOT_LESS_OR_EQUAL
file path: C:\WINDOWS\system32\drivers\ucx01000.sys
description: USB Controller Extension
Bug check description: This indicates that a kernel-mode driver attempted to access pageable memory at a process IRQL that was too high.
This bug check belongs to the crash dump test that you have performed with WhoCrashed or other software. It means that a crash dump file was properly written out.
if anyone has any advice for fixing that would be great.
Please list your full pc specs.
sorry for the late reply
OS Name Microsoft Windows 10 Home
Version 10.0.19042 Build 19042
Other OS Description Not Available
0S Manufacturer Microsoft Corporation
system Name DESKTOP-LSDPDGI
system Manufacturer To Be Filled By O.E.M.
System Model To Be Filled By O.E.M.
system Type x64-based PC
system SKU To Be Filled By O.E.M.
Processor AMD Ryzen 5 2600 Six-Core Processor, 3400 Mhz, 6 Core(s), 12 Logical Proce...
BIOS Version/Date ‘American Megatrends Inc. P5.20, 6/28/2021
SMBIOS Version 3.3
Embedded Controller Version 255.255
BIOS Mode Legacy
BaseBoard Manufacturer ASRock
BaseBoard Product B450M Prod
BaseBoard Version
Platform Role Desktop
Secure Boot State Unsupported
PCR7 Configuration Binding Not Possible
Windows Directory C:\WINDOWS
system Directory C:\WINDOWS\systemn32
Boot Device \Device\Harddiskvolume1
Locale United states
Hardware Abstraction Layer Version = "10.0.19041.1151"
User Name DESKTOP-LSDPDGI\auscw
Time Zone Central Standard Time
Installed Physical Memory (RAM) 16.0 GB
Total Physical Memory 15.9 GB
Available Physical Memory 11.7
Total Virtual Memory 18.8 GB
Available Virtual Memory 13.1
Page File Space 2.87 GB
Page File C:\pagefile.sys
Kernel DMA Protection off
Virtualization-based security Not enabled
Device Encryption Support Reasons for failed automatic device encryption: TPM is not usable, PCR7 bindi.
SMBIOS Version 3.3
BIOS Mode Legacy
BaseBoard Version
could you post a cpuz screenshot on the mainboard tab? also what gpu and psu did you use?
