Question Constant BSOD and issues when GPU is vertical
king2096
6
So I’ve run into an issue with my GPU whilst having it vertically displayed with a riser cable. When mounted horizontally it is fine. I’ve check that all screws are in place and that all the standoffs required are even, etc.
I did have one day where it worked perfectly fine and then the next decided to do the opposite so I’ve had to resort back to the horizontal mount .
Case: Deepcool Macube 550
Riser: Deepcool PEC 300
Mobo: MSI B450
GPU: MSI radeon 5700xt gaming x
PSU: cooler master 750w gold
CPU: Ryzen 3600
RAM: 16GB 3200mhz
Really want the vertical mount to work due to watercooling. Any help would be much appreciated.
Thank you
