Contorl Panel --HELP
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.newusers (More info?)
Hello
I'm having difficult in accessing the Control Panel...
The page will appear, but then it turns itself off, brings up a blank page
(which is my desktop picture I had chosen)
After a short pause, the desktop icons appear.
I have not made any changes or added anything that would be adding to the
problem....but each time I try to go to the Control Panel, it does the exact
thing.
Anyone who could help me out with this ???
Thanks for any assistance or suggestions.
Amber
Hello Amber:
Since you did not mention which version or Windows XP
you are running, here are intructions for both Home and Pro
Editions, and logon preferably with the administrator account.
For Windows XP Home Edition, you must logon in Safe Mode..
For Windows XP Professional Edition in normal logon..
In the Windows Explorer, go to Tools\folder options\view\go to
the bottom of the list and uncheck "Simple file sharing
(recommended) then in C:\WINDOWS\System32\search for
"control.exe" right click on it and go to properties.. in the Scurity
tab\see if your account has full permissions if not, check total
control so all permissions are ticked, click accept and exit....
try the control panel now... if no success, go again to the
security tab in control.exe properties, and go into Advanced
Options\Owner and take ownership. check total control again.
If that didn't work, try this ONLY if you have WinXP Pro Edition...
go to Start\Run\gpedit.msc\User Configuration\Administrative
Templeates\Windows Components\Control Panel\Prevent
Access to Control Panel... set this directive to Not Configured....
If you do not have access to eiter the Group Editor or do not
have permission to take ownership of files, install the following
spyware scanners if you haven't installed them allready, as it's
posible a spyware/hacker trojan has removed permissions from
your account.
Spybot Search and Destroy (Free) Update it before scanning.
http://www.safer-networking.net/en/download/index.html
Lavasoft AdAware (Free) update it before scanning.
http://www.lavasoft.de
How To Take Ownership of Files and Folders in Windows XP
http://support.microsoft.com/default.aspx?scid=kb;en-us;308421&Product=winxp
How To Set, View, Change or Remove Special Permissions in Windows XP
http://support.microsoft.com/default.aspx?scid=kb;en-us;308419&Product=winxp
--------------Original Message------------
"Amber" <Amber@discussions.microsoft.com> escribió en el mensaje
news:8F4C3A18-32A8-461F-95A4-5E9DA28F316F@microsoft.com...
> Hello
exact
> thing.
> Amber
