Question Cooler for FX8350
Are you having temperature issues? While that cooler is a bit 'old school' at this point, if it works sufficiently, I wouldnt' recommend investing any money into the platform. If your temps are excessive (and you've cleaned etc), then a cheap cooler like the 212 should suffice.
Well the temps go to 75C° while gaming and ive got 5 fans in my case
I'm not 100% here, but IIRC, most software doesn't capture CPU temps accurately, and they're inflated by X'C.
I believe AMD Overdrive, measuring Thermal Margin which works backwards (degrees to 0) is the way to go for FX chips.... but not 100% on that.
Hopefully someone else can confirm.
