cooler for i5 4670k?
Kristokev23
6
Hi, can anyone please suggest what cpu cooler for that cpu? And is it corsair h100i fit to my case (corsair obsidian 450D)? Someone help me
Thanks alot guys!!
The Corsair h100i will work perfectly fine in the Obsidian 450D case as they were designed to work with one another. It is also one of the better liquid cooled units out there.
Closed liquid coolers are little better than high end air coolers. I therefore would council you to purchase a silver arrow or a Noctua NH-D14 as mentioned by alan. Large air coolers have the advantage of replaceable fans if one was to die out(rare). All in one liquid cooler has a higher chance of failure and is more expensive.
Thx a lot mate. im just afraid it wont fit, since the gap between the mobo and the top case is pretty small
mm what do you mean by silver arrow? sorry for stupid question, since this is my first build
cheers
http://www.thermalright.com/html/products/cpu_cooler/silverArrow_sb-e_extreme.html
Big air coolers are better in terms of value, they are only a few degrees warmer than the highest end closed liquid coolers.
