Question Cooler for LGA 1700 i5 12600k?
smrdelj
20
Hello everyone, thanks for your help! I bought an i5 12600k and a Gigabyte Z690 Gaming X DDR4. I have a Corsair H100i v2 water cooler that would not be compatible so I would need to buy a new one. I will use the pc for gaming. Maybe I'll do some OC (most likely not), but anyway nothing extreme. I have read that there are few compatible coolers "out of the box". So I'm kind of lost. I also don't know if water or air would be better. I would like to spend only what is necessary from a functional perspective, I am not interested in paying for RGB or anything like that. Recommendations? Thank you!
Budget for your cooler? Preferred site for purchase?
I'd look into a 240mm AIO at the very least or go upwards from there. You could look into the Be Quiet! Dark Rock Pro 4 if you want to have headroom when overclocking but with a 150W TDP(and then some more) on the processor, I'd look into beefy coolers.
Reactions: smrdelj
Ok thanks! In my country Id Cooling coolers are much more cheaper than others, so id go with the frostflow x 240, its 250 tdp and looks pretty identical to my corsair h100iv2.
It might be worth checking with Corsair about a mounting kit for your H100i v2
