I just built a new system it has a I5 760. My room gets pretty hot in the summer and I was wondering it would be worth it to get a better solution for removing the heat then the stock fan it came with. It tends to run at somewhere between 35C to 58C depending what i am doing,mostly gaming and surfing. So would it be worth me buying a cooler of some sort before summer would it make a difference? If so what would a good cooling solution to get? My budget is probably around $60ish I also live in Canada.
Thanks
Thanks
