hello everybody I just bought a Cooler Master Elite 430 and installed everything in it. However I ordered the Cooler Master Hyper 212 plus from amazon for 25$ free shipping. Anyways i also bought Rosewill 120mm RCA-1204BK it came in a four pack. at 9$ you can't go wrong eh? Anyways my question is this Do I need dust filters on the rear bottom and side fan panels? also Should I upgrade to a 140mm LED fan in the front? By installing the Cooler Master Hyper 212 plus Will I still be able to mount the top 120mm Fans? And finally Can you give a me a fan setup of where I should place the fans. What place would be more effective. I don't have my motherboard so don't ask me what model number it is. This is a very nice case I picked for Price/performance ratio. It can mount up to 6 fans
Cooling System
-Top: 120 mm fan x 2 (optional)
-Front: 120 mm blue LED fan x 1, 140 mm fan x 1 (optional)
-Rear: 80/90/120 mm fan x 1 (optional)
-Side: 120mm fan x 1 (optional)
-Bottom: 80/90/120 mm fan x 1 (optional)
It came with a nice cooler master LED 120mm fan. If I get a 140mm I will put that fan somewhere else in the case. SO total I have 5 Fans Currently that I can install in there with 1 already installed. The Rosewill fans are excellent they are 18 DBA so quiet! So should I buy a 140mm fan to mount on the front. Preferably LED Blue
another 120mm to add onto the Cooler Master Hyper 212 + for a push/pull configuration. Then should I buy another fan to go on the side. Those are all my question I need help with them all. Also I have a Corsair Cx430 Power supply with a 120mm fan. I mounted it with the Fan facing the dust filter so tell me if that's a good decision. I love the look of this and I got it cheap 35$ If I buy fans please suggest some high rating cheap 120mm-140mm Fans so I cna take advantage of all the slots. It doesn't have to be LED. But LED is preferable.
In my case I will be running the folllowing Fans:
4 Rosewill RCA-1024BK
1 Cooler Master Blue LED 120mm
1 Nvidia Geforce 8800 GTX Graphics Card fan
2 Coller Master Hyper 212 + Fans mounted
1 120mm Corsair Power Supply fan
Total of 9 fans running in this case. DO I need them all are dust filters necessary. Will this setup be very very loud. Please suggest some good cheap fans o me to buy.
Thank you BTW My name is Preston. Thanx for looking and answering all my questions. this is my first PC build ever at 14
Cooling System
