Cooler Master HAF X High-end fan replacement
XAKEP
343
Evening guys ! I am trying to get my stock fan replaced with 4 pin high-end fans that will work with my case. I found nice one for that back but front and side I can't find a proper one. I tried to get a side fan, I matched up size but screw positioning does not match original and wouldn't work.
So can anyone recommend 4pin "premium" fan that will fit HAF X case.
Thank you.
Here's a guide to removing the side fan just for the sake of relevance. The fan on the side panel looks more akin to a 200mm fan but with mounting holes for 2x120mm and 140mm fan mounts. You;d be best served by getting a ruler and measuring the hole distances(center to center on one side) on your side panel.
Outside of that you can look towards these suggestion:
http://www.overclock.net/t/1189910/replacement-fans-for-haf-x-case/0_100
https://exterminatus.eu/general-discussion/bitfenix-fan-installation-coolermaster-haf-x-t6261/
http://www.tomshardware.com/forum/304916-31-case-fans
+ finally:
https://www.youtube.com/watch?v=Iddk6S-LhNM
+ finally:
