Cooler Master Hyper 212 EVO loud noise upon startup
ChewbaccaBreath641
30
My Hyper 212 is making a very loud and obnoxious sound that almost sounds like the unit is shaking as it's spinning, the thing sounds like a helicopter. This only happens upon startup, there has been times I have left my PC on sleep mode for days and it never occured but as soon as I restart, there it is again. I have to take the side panel off and messed with it for a little bit to get it to stop which usually takes a few restarts. This time I gave it a little slap, stupid I know but get this, it immediately stopped making the noise. [video="https://www.youtube.com/watch?v=lWpLwomiYwg"][/video]
Sounds like the fan is hitting the side of the heat-sink, probably due to a bad bearing as mentioned earlier. You could also try dusting your case and the problem fan to see if that helps or separate the fan from the heat-sink completely and make sure there are no obstructions. Sometimes moving the fan from one side of the heat-sink to the other works as well.
It doesn't make sense that it only starts when the PC is started up, what I mean is that I can have it on for days straight and only put it in sleep mode and it won't happen but if I turn it off it will when I turn it back on.
If I just replace the fan should it solve the problem? That would be a lot cheaper than getting a whole new hyper 212.
It always sound loud when started as it goes max rpm. But your sound shows there something wrong with it. I would say it hit the heatsink a bit. If its unfixable then its time to buy replacement fan.
Here are some example. Make sure it support variable speed for your motherboard to control its speed.
$5.39 Rosewill RNBF-131209 - 120mm Computer Case Cooling Fan with LP4 Adapter - Black Frame & Smoke Blades, Sleeve Bearing, Silent
https://www.newegg.com/Product/Product.aspx?Item=N82E16835200087R
$5.99 DEEPCOOL XFAN 120 Hydro Bearing Black Fan
https://www.newegg.com/Product/Product.aspx?Item=N82E16835856019
$6.99 DEEPCOOL XFAN 120L/B Hydro Bearing Transparent Fan with Blue LED
https://www.newegg.com/Product/Product.aspx?Item=N82E16835856017
hydro bearing should be better than sleeve bearing.
$9.99 DEEPCOOL UF 120 PWM Fan 2-Ball Bearing Rubber Coating De-vibration Deep Silent
https://www.newegg.com/Product/Product.aspx?Item=N82E16835856014
Ball bearing more reliable.
pick your most suitable taste
And yes, they are not high static pressure type. But it will work just fine, especially the $9.99 one.
I have an Asus P8Z77-M MOBO
