Cooler Master or Thermaltake
Papichoolo
4
Is THERMALTAKE TR2 700W-NON MODULAR (TR-700PCEU) better or Cooler Master GX 750W?
In terms of pure power, sound isn't much of a problem.
I don't have any budget to go higher then these specs so please tell which one is better in between these two, any in there range.
neither are any good. get a reliable brand like Antec, Corsair, Seasonic or XFX. thermaltake tr2 and many colermaster products are known for being overrated (they cant produce their rated power). ALL antec, corsair seasonic and XFX psu's available will produce their rated power at continuous load at high temperature. What are you trying to power. a good 600w psu will power pretty much any high end cpu and gfx card. 750w is only really necessary if your going to sli/crossfire a pair of 6970's or gtx 560ti's + run an overclocked cpu.
Well the TR-700P recently received a positive review at Hardwaresecrets (whereas the Seventeam built GX 750 RS-750-ACAA-E3 received a negaitve review at that site). If it is the Enhance built RS-750-ACAA-D3 then that is better than the Seventeam one, but I haven't seen a review for it yet so don't know if it is better or worse than the TR-700P.
http://www.hardwaresecrets.com/article/Thermaltake-TR2-700-W-Power-Supply-Review/1422
http://www.hardwaresecrets.com/article/Cooler-Master-GX-750-W-Power-Supply-Review/917
If we knew where you are buying from, what your budget is and what your system is then it might be possible to find a better unit.
