Cooler Master SickleFlow 120mm fan screws
AlmostAscended
6
When I tried to install them onto my case for a new build, I realized that the fan's screw holes were not threaded and wayyyy to small for the included screws. I'm just wondering what's the best way to install these. Find smaller screws? Try and force the screws in? Use an electronics screwdriver/drill and drill the screws in? Is there a chance of breaking the plastic screw holes on the fans?
Thanks
AlmostAscended
6
Yes, I believe they are: they have the raised threads like in the wikipedia pic. Thanks!
