[SOLVED] Cooler on 10700k in mini-ITX Case
Jan 8, 2021
Hey,
I needed to rebuild a pc, from mostly new Parts, but I thought the case and psu are still fine.
Lian Li PC-Q08 mini-ITX Case
10700K
H470M-ITX/ac
normal atx PSU
So I had a Corsair H60 in the old build(which I know is not very great being a 120x120 in this case), but the CPU Cooler Clearance is only around 100mm.
I'm guessing the H60 can't really handle the 10700k, so which cooler should I use that still fits in the case, or do I need to get a new case, which I thought I could avoid.
Cheers
