I just put together a new system for my sons gaming and have some cooling fan issues,
the mobo i have has limited fan headers so i need some advice at this point,i will list the parts below also.
i have 2x 3pin fans in the front of the case(not rgb or argb) 1 rgb fan on cpu cooler and 1 argb fan at rear of case,
the mobo only has 2x rgb headers and a few 4pin headers.
the front fans i cannot power at all atm.
im wondering should i just a few more rgb fans and add a rgb hub? if yes what hub is suggested?
https://www.scorptec.com.au/product/cases/atx/77983-ca-h510b-b1
https://www.scorptec.com.au/product/motherboards/amd-socket-am4/83420-tuf-b450m-pro-gaming
https://www.scorptec.com.au/product/cooling/cpu-coolers-air/75670-rr-212s-20pc-r1
https://www.scorptec.com.au/product/cooling/120mm-fans/82021-mfl-b2dn-18npa-r1
