This may be completely unrelated, but as I was sitting on the jon today doin a number 2 and I was thinking about the theory of cooling, specifically the differences between air and water cooling.
Some mainstream water cooling sets don't outperform the best of air cooling solutions and I was wondering WHY? I mean isnt it that, using the basic laws of physics, water has more particles densely packed together rather than a gas (air)? I was also wondering the this sitting in the pool, how there was a railing leading into the pool and where the metal was out of the water it was hot as hell (sun) and the metal in the water was really cool to touch (obviously). I was thinking since, there is such an obvious difference shouldn't this be the case with water/air cooling computer components?
Then I got to thinking, how can I improve water cooling performance, and how is it that air cooling can do such a great job. Imagine blowing on a heat source, it doesn't cool down that quick. Splash some water on it and its already mild/cool to touch. Because of the fact that water has many more particles per area to transfer the heat energy from the heat source, to the water particles themselves. Heat cannot dissapear, its only transferred.. and is the last form of energy for those of you who studied basic physics before. Water should be the better conductor than air. More so than that, solids should be a better conductor than water. That lead me to thinking of a hypothetical, ideal heat conductor. A never ending, ever lasting long or big, solid. Thats the reason for the growing sizes of heatsinks. Its basically a solid taking away heat energy from the heatsource, only to be trapped in the heatsink, waiting for dissapation from the active air cooling of fans. If that does such a good job already, why isnt water that much better?
Heatsinks are designed to not only be big to retain more heat capacity (in the literal sense) but also with greater surface area for air to pass through. Why can't this work with water? instead of having a water block, why can't we design a heat sink with great surface area, and water pass through to transfer the heat energy away? So I'm thinking an ideal heatsink in my opinion, would be a big heatsink with many fins, in some sort of enclosure so that water can pass through the whole thing. Wouldn't this be better than a waterblock? Its basically having the heatsource transfer the heat in the best way possible - heatsource (solid) to heatsink (solid) and having water actively transport heat away. Solid to solid conductors are the best and fasest arent they?
But then you've got the problem of the heat in the water to transfer to somewhere else, because to cool effectively you need to TRANSFER heat. And the heatsource can never be cooler than the heatsink itself. Would this theoretical 'ideal' cooling solution be better than current water cooling solutions? Basically its has an addition of using a larger surface area heatsink for the water to pass through.
