Hey guys, I just installed the corsair A70 onto a i7-860 which is on a Asus P7P55D-E Pro MOBO,
I am having trouble figuring out which fan plugs should be plugged into which fan header?
Mainly with the corsair A70 CPU cooler, it has two fans which i replaced with two LOGISYS Computer SF120 120mm Extreme Quiet Rubber Fan that plug into a splitter that i have plugged into the 4pin cpu header, however right next to that header there is anther 4pin headder called channel fan1..
I have the corsair sniper case with the fan controller taken out, i did not like the way that was set up, so i have the top, side, and front fans running and connected to molex connectors, i dont care about lights....
the rear fan is a XIGMATEK Cooling System XLF XLF-F1255 120mm Power Management Case Fan PSU Molex Adapter/extender included... i have that plugged into the 4pin channel header with out the molex adapter....
So im really not sure the proper way to get this set up, i know this MOBO has a function called Q-fan and in the BIOS it cant read one of the fans and i think it has something to do with the way i have the corsair A70 Fans hooked up, which again are these
http://www.newegg.com/Product/Product.aspx?Item=N82E16835999007
and the exaust fan is this one, which you will see does come with a molex connector which im not usring right now
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233045&cm_re=xigmatek_120mm-_-35-233-045-_-Product
Any help in understanding the proper way to get the MOBO to read these fans would be great!
Thanks all,
Ed
Thanks all,
Ed
