corsair fan question
May 30, 2018
34
hey guys so i have 5 ml140 fans and have the corsair link application and it shows fan 1 and 2 on the motherboard at a max speed of 600rpm when in reality the fans can go up to 1200rpm and when i go to add in a max and min rpm it doesnt change anything, maybe i just dont know how to use the application? any suggestions or help is appreciated
below are my specs
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor ($459.99 @ Amazon Canada)
CPU Cooler: Corsair - H115i PRO 55.4 CFM Liquid CPU Cooler ($164.99 @ Amazon Canada)
Motherboard: Asus - ROG STRIX Z370-E GAMING ATX LGA1151 Motherboard ($244.99 @ Amazon Canada)
Memory: Corsair - Vengeance RGB Pro 16GB (2 x 8GB) DDR4-3200 Memory ($275.99 @ Newegg Canada)
Storage: Samsung - 860 Evo 500GB M.2-2280 Solid State Drive ($178.99 @ PC-Canada)
Storage: Western Digital - Blue 1TB 2.5" Solid State Drive ($294.99 @ Mike's Computer Shop)
Video Card: EVGA - GeForce GTX 1080 Ti 11GB SC Black Edition Video Card ($1019.99 @ Mike's Computer Shop)
Case: Phanteks - Enthoo Pro M Tempered Glass (Black) ATX Mid Tower Case ($134.99 @ Amazon Canada)
Power Supply: Corsair - Professional 750W 80+ Gold Certified Semi-Modular ATX Power Supply
Operating System: Microsoft - Windows 10 Home OEM 64-bit ($114.75 @ Vuugo)
Case Fan: Corsair - ML140 PRO RGB 55.4 CFM 140mm Fan ($49.99 @ Amazon Canada)
Case Fan: Corsair - ML140 PRO RGB (2 pack w/Lighting Node PRO) 55.4 CFM 140mm Fans ($119.15 @ Amazon Canada)
Monitor: Asus - VG248QE 24.0" 1920x1080 144Hz Monitor ($328.50 @ Vuugo)
Keyboard: Razer - Ornata Chroma Wired Gaming Keyboard ($122.50 @ Vuugo)
Mouse: Razer - DeathAdder Elite Wired Optical Mouse ($69.99 @ Amazon Canada)
Total: $3698.95
Generated by PCPartPicker 2018-06-27 01:58 EDT-0400
can you give the link for the ai suite 3 download link, i cant find a proper download link, and yea i have icue controlling my pump fans and led, just need something to control my other 3 fans
I mean you don't have to use AI Suite 3 that was just an example (I'm pretty sure you need an Asus motherboard to even use it idk i've never tried). To be honest I only use it because it came with my MB, it also does a lot of useless crap you will never need to use.
I would ask around and figure out what a good software to use is and go with that.
My point is just that Link is terrible. I've never been able to get what I want out of it. I'm really thankful they moved to iCUE to integrate all their performance and lighting settings.
