Corsair H110 extreme won't mount 1150 socket properly
quigg15405
21
I'm trying to install it on a msi z87 gd45 board, but no matter which combination i use to screw the cpu cooler in, it just won't fit! Even if i do get three in properly, the last one needs a ridiculous amount of force to get it to match the hole, and that just leaves the fourth one on an uncomfortable angle. I've rechecked all the parts and made sure they are for 115x.
I have seen other users report incompatibilities with high end gaming boards (with beefy heat sinks) and Asetec ALC coolers (Asetek makes coolers for Corsair and others). OTOH, normal WC blocks work just fine.
I'd suggest a real water cooling kit such as:
http://www.frozencpu.com/products/16551/ex-wat-217/XSPC_Raystorm_EX280_Universal_CPU_Water_Cooling_Kit_w_D5_Variant_Pump_Included_and_Free_Dead-Water.html?tl=g30c321s1310
or if budget is tight
http://www.frozencpu.com/products/20926/ex-wat-266/XSPC_Raystorm_750_EX280_Extreme_Universal_CPU_Water_Cooling_Kit_New_Rev_4_Pump_Included_w_Free_Dead-Water.html?tl=g30c321s1310
Another option is the Swiftech 220 ... they move the pump from the CPU toi the radiator which makes the WB...
Another option is the Swiftech 220 ... they move the pump from the CPU toi the radiator which makes the WB smaller .... and avoids any patent issues with Asetek..
