[SOLVED] Corsair H115i wiring / cable issues
Jul 11, 2020
I am building a PC and using Corsair H115i platinum AIO and have come up with the below wire (in the pic)...Please could you tell me where does this connect to ?
System Specs:
AMD Ryzen 7 3800X
Gigabyte X570 AORUS PRO WIFi
NZT H519 elite
Gigabyte GeForce RTX 2070 SUPER
Those look like the ARGB output connectors attached to the PUMP unit of the system. You plug into them the lighting cables from each of the two rad fans. CHECK to be sure that the MOTOR cables from the fans connect to a DIFFERENT output from the pump unit.
The instructions say that the lighting displays will start with the fan you plug into output #1, so choose which fan you want in that role.
