Question CORSAIR HD RGB Fan LED Controller how do I connect to motherboard
Yes, this item is the MANUAL control box you can connect to the actual RGB Controller Box by Corsair that your fans are connected to. Normally it is used only when you are NOT making a connection from that Control Box directly to a mobo RGB or ARGB header and NOT using the iCUE software utility with Corsair hardware.
Tell us exactly WHAT fan(s) you have, what (if any) extra boxes came with them, and the exact maker and model of you mobo. With those we can look up the details and provide more complete instructions.
Reactions: Dark Lord of Tech
