CORSAIR Hydro Series H60 Liquid CPU Cooler for i5 6600k ?
InFamous-N-
Commendable
Jul 15, 2016
8
Good day fellow members,
I have a dilemma, i have recently purchased an I5 6600k cpu and as it does not include a cpu cooler.
Thus i find myself here seeking advise , its my first build and due to me spending half my budget on the cpu alone , im trying to find the best possible solution for my build / budget.
I want a cooler that will perform well with this chosen cpu as well as be silent .
My budget is $80 which is the cost in my country for the H60.
the mobo for the build will be a msi H110m gaming ( will upgrade later on )
Another comparison to the H60 would be the DeepCool MAELSTROM 120 ( would this be as good or better?)
Thank you for your time and feedback, will be much appreciated.
http://www.coolermaster.com/cooling/cpu-air-cooler/v6gt/
165mm high, so given that the 212 series only sometimes fits the Spec-02 and Spec-03 cases, I'm pretty sure it will be too big.
Also, noise levels don't look very good for that cooler, looking at a couple of reviews:
http://www.guru3d.com/articles_pages/cooler_master_v6_gt_review,8.html
http://www.tweaktown.com/reviews/3371/cooler_master_v6_gt_cpu_cooler/index6.html
As far as price, that TweakTown review said the MSRP was $69.99 when it came out, so $50 seems a bit high for a 3yo used model.
Good day,
Thank you for your prompt reply,
My apologies for my late response as work gets hectic etc..
Anyway I have checked my local stores etc but they all only offer the 212x (which is different from the 212 evo correct? )
What about the DeepCool MAELSTROM 120, CPU Water Cooling ? would it be any good?
However In all my research i have found that there is a 50/50 of people stating the H60 is silent and good whereas others state its loud.
Forgive me for my silly inquiries , its just that i am a noob to all this, and just want my pc running well and getting value for my money.
My statement about closed-loop coolers was a general one, rather than specifically about the H60. I suggest you look for some professional reviews that actually measure the noise produced by the H60 (or the DeepCool Maelstrom) and compare it to some common air coolers. I presume you've already made sure it will fit in your case, which you haven't specified. Some cases are better at blocking noise from the fans inside, and depending on how far it will be from you, and if the furniture will provide extra barriers, that could affect how much of a problem the noise will be.
Also, you should take into consideration that closed loop coolers are not immune to leaking, and read through the Watercooling Sticky if you haven't already: http://www.tomshardware.com/forum/277130-29-read-first-watercooling-sticky
P.S. I wasn't familiar with it when I first replied to your message, but there's a different air cooler that has quickly become more popular than the Hyper 212 Evo as the default recommendation due to its better case and memory compatibility: the Cryorig H7. (the Hyper 212x has some enhancements to the airflow compared to the evo model, but is 158mm high, which is too tall for some cases, and presumably still overhangs the memory area, interfering if the ram has tall heatspreaders)
If you can fit any of the $50-$80 air coolers in your case and over your RAM they will be a better solution. They cool better than 120 WC AIO units. If you are not OCing than a 212 or similar $20 air cooler would be more than enough.
Thanks for the feedback,
I am currently looking at purchasing the 212x but am trying to get its dimensions although i now worry about that ram slot space.
The motherboard - msi b150m gaming pro
case - Bitfenix comrade
Now i am going to have to check if these components will fit perfectly without any size issues.
this is the website and the seller i will be purchasing from
http://www.rebeltech.co.za/
The Hyper 212x is 158mm high, 120mm wide, and 79mm deep: http://www.coolermaster.com/cooling/cpu-air-cooler/hyper-212x/
Strangely, BitFenix doesn't seem to list the cpu cooler clearance. However, given how little horizontal space there is between the rear 120mm fan, the cutout for the motherboards rear ports, and the side panel, I'm guessing the Hyper 212x would not fit in that case, and you might have trouble fitting a closed-loop cooler like the Corsair H60 in that case as well. Unfortunately, the Cryorig coolers aren't listed at Rebel Tech.
The Cooler Master Hyper D92 is 145mm high, so it should fit, but it might not be as quiet or as effective as you'd like.
Since that board is not made for overclocking look at the Cryorig H7, or for 20 bucks the Cryorig M9i would even work.
Please read the other posts more carefully before making posts like this.
1. The OP has stated an intention to upgrade the motherboard later on, so it being poor for overclocking doesn't matter that much.
2. The OP plans to purchase components from the Rebel Tech website (in South Africa, based on the suffix), which does not carry the Cryorig cpu coolers.
3. I quoted the origenal post that said nothing about where he could buy parts.
4 Will upgrade later the H7 has better performance that a 212 and fits.
unfortunately cryorig products are very rare to find in my country (South Africa)
If it is available here, i am unaware off it.
I would like to go with the 212x as its ratings are good and i can try and get a case that will fit it. only the ram concerns me, but im sure if i get a set of corsair 8gb ram without tall heatspreaders.. it should not be an issue.
Thank you all for your feedback/responses, it is highly appreciated.
@ MauveCloud, Your detailed responses were off much help and enlightened me.
I will review the 212x and the cryorig H7 ( if this holds no issues i will try to purchase one off ebay).
In case you have trouble getting the Cryorig, here are a few case suggestions:
1. the case model I'm currently using, the Corsair 200R (165mm cpu cooler clearance), though I see it's rather expensive at Rebel Tech.
[strike]2. Raidmax Vortex V4 (though Raidmax psus have a bad reputation, so I don't know whether to trust their cases, but this model has 160mm cpu cooler clearance according to specs, and it's only a little more expensive than the BitFenix Comrade)[/strike]
3. BitFenix Nova (also 160mm cpu coolear clearance, and actually listed in specs, unlike the Comrade and Neos models)
Case wise - I am looking at the corsair SPEC-01 / 02 / 03 (must be windowed)
You will also find them on the rebeltech site.
How do you guys find out the cpu cooler clearance measurements for cases? most do not state .
I had found this build with a 212x with a corsair spec-02 case https://pcpartpicker.com/user/Maitha/builds/
The manufacturer sites often list the cpu cooler clearances in the tech specs.
Corsair Spec-01: http://www.corsair.com/en-us/carbide-series-spec-01-red-led-mid-tower-gaming-case (150mm cpu cooler clearance)
Corsair Spec-02: http://www.corsair.com/en-us/carbide-series-spec-02-red-led-mid-tower-gaming-case (157mm cpu cooler clearance, so I'm not sure how "Maitha" got the 212x to fit, since it is officially 158mm high)
Corsair Spec-03: http://www.corsair.com/en-us/carbide-series-spec-03-white-led-mid-tower-gaming-case (157mm cpu cooler clearance)
Okay, given the beveled edges around the side window of that case, I can believe that. Different motherboards may slightly change where the heatpipe ends meet the case side. I remember once finding that the backplate cutout of an ATX case didn't line up well enough with the cpu position of a micro atx motherboard for me to actually install the backplate with the motherboard still in.
Evening Gents,
I received an offer on a cooler master v6 GT cpu cooler @ $50 , its used / three years old, but friend states its in good condition and i trust his word.
But would appreciate your perspective whether or not it may be a good buy at such a price for my build and compatibility wise. and would i still get some good years out off it you think ?
He has a i5-4960k and stated that it ran smooth and very quiet.. my main concern for my cpu cooler would be its noise level.
Please advise....& thank you in advance.
