BlazingAngels Distinguished Feb 21, 2015 119 1 18,595 Feb 13, 2023 #1 I purchased a Corsair iCue 7000x and I needed to remove the side panel to install a GPU while the case is horizontal. Would a standard number 2 Philips head be able to unscrew the side panel or do I need to purchase a special screw driver?
Lutfij Titan Moderator Oct 7, 2009 58,915 6,089 178,440 Feb 13, 2023 #2 View: https://youtu.be/LsKiCLBGtSM?t=197 I don't think so, though you don't need bother with opening the glass panel off it's hinges when the case is in the upright position. Upvote 0 Downvote
