Corsair Veng Pro 2400 Voltage- Intel 4790K
mapkos13
20
Warning about voltage of 1.65c exceeds maximum CPU recommendation of 1.5v (1.575)...
I've read about manually adjusting and using an XMP profile to bring it up.
A few of questions:
1) Is there a method that is easier/better than the other?
2) Does anyone have the settings that work already?
3) What is the max I can drive these for the speed and voltage?
4) Would it be better to scrap the sticks for something else altogether?
Similar question but I thought I'd be specific to my setup utilizing the following:
Thanks all-
4790K
Corsair Vengeance Pro 2x8 2400 (C11R Version) 11-13-13-31 1.65V ver 5.21
Asus Z97-AR MB
MSI GTX 970 Gaming 4G
1.5 is suggested for CPU at stock and running 1600 sticks, 1.65 is perfectly safe and in fact is the 'standard' for 2133 and up DRAM - those should be fine with your rig 😉
