Corsair Vengeance 8Gb Dual Recognising Problem
omerkorkmaz
5
Cpu : AMD Fx(tm) 6200 Six core 3.8Ghz
Motherboard : Asus M5A97 Evo R2.0
Memory : 2 -Vengeance® — 8GB(2x4) Dual Channel DDR3 (CMZ8GX3M2A1866C9)
Hi, I am having an issue with my memory and motherboard. I already tried many thing.
I have totally 16GB ram but. It always shows totally 8GB. When i take off one of them it shows only 4GB which should be 8GB. I updated bios to bios late version and tried all slots blue-blue or black-black. Before when i update bios it was show 8GB 1333 MHz . After when i update bios and change advanced setups it shows 8Gb 1866 MHz
Ai Overclock Tuner Manuel
Dram timing 9-10-9-27 (I also tried 9-9-9-24)
Dram command Rate 2T
Dram Voltage 15.50500
Any help would be greatly appreciated.
Thanks
Missing the memory size in your post (red ?).
I have 2 sets of 8Gb(2x4) 1866 MHz DDR3 totally 16Gb.
Before changing bios setup it was show 8gb 1333MHz. Now it show again 8Gb but 1866MHz. Which Should be 16Gb and 1866 Mhz.
Thanks.
First check that "Maximum Memory" is unchecked in "Boot Advanced Options" (Start > MSCONFIG > Boot tab > Advanced options).
Showing half available capacity of memory suggests either faulty memory or faulty slot. Or possibly memory is not (fully) compatible with the system?
Try the memory in another computer. And/or try other memory in the computer.
I just checked but it shows half also.
You can see detail below on photo.I can't test them from another pc or i can't test new memories on this pc. coz i haven't got on other pc or memories 🙁
Repeating my previous post, remove the check mark (tick mark) in the Maximum memory box in "BOOT Advanced Options". And just to be safe, you could also set the memory from 8192 to 0, although this is not critical as long as the maximum memory is UNchecked.
Alternatively, the check mark could be left in the Maximum memory box PROVIDED that the memory value is changed from 8192 to 16384.
The preferred option though is to uncheck the Maximum memory box so there will no longer be any memory limitation set by the operating system.
Once the above procedure has been done, check memory again.
After your post i already unchecked than safe but nothing didn't change everything is same. It still shows 8192 on bios or computer properties or msconfig boot. SO my problem still continuing 🙁 I thought it is about bios setup that is why i uploaded bios pictures. But some reason they deleted them. Do you have any other suggestion.
Thank you.
