Hello, Thank you for the time you are willing to take to respond to my thread!
I recently upgraded my GPU from GTX 750 to RTX 2070 , to have over 300 fps in CSGO all the time.. I thought buying a 500€ card would just fix the fps problem but nope, it didnt. I only get a 50 fps boost in CSGO and when I see enemies or Molotov etc it drops again to 180 fps which it makes seem really not smooth at all... And I did not paid 550€ to play 180fps still in CSGO
My Components:
RTX 2070 EVGA Black
I7-9700k @ 3,60GHZ
16 GB RAM Solo 2400mhz (Overclocked to 2600mhz)
Thermaltake 600W
Asus B360M-K
Since I do not know what to upgrade to get more than 300 fps all the time I decided to replace my ram to
Corsair Vengeance RGB Pro 16GB (2x8GB) 3600MHz
Amazon Link: https://www.amazon.de/Corsair-Venge...=16gb+ddr4+3200mhz&qid=1593526084&sr=8-4&th=1
I do not know if it's a good idea to replace the RAM or not... But if it is please let me know guys if I could upgrade or if its compatible the ram I want to buy
My Components:
RTX 2070 EVGA Black
I7-9700k @ 3,60GHZ
Thermaltake 600W
Asus B360M-K
