[SOLVED] could somebody please help me by building a 1000 pound system
Jul 5, 2021
19
My approximate date to buy this is in late November late December
My budget is 1000 pounds uk
I would like to stream games at 1080p 60fps or if possible 1440 60 fps
I do not need peripherals
I do not need a copy of windows
I would like to buy items off of trusted websites
I live in the uk,england
I would like an amd cpu and a nvidia gpu
I would like to overclock my gpu a bit
My moniter resolutions is 1080p or 1440p
i would greatly appreciate any help given and i thank you if you do help me
As I am sure you are aware there is a serious GPU shortage going on right now.
What I might recommend is that you shop the trusted retailer in your locale and see what kind of budget you can find a card for, if it's in stock. Expect things like the 1050ti or 1650 to be the best you can find under $3-400. Either of those cards should do low/mid settings 1080/60 in 'many' games. They have been around a long long time and benchmark reviews are all over.
After that aspect is said and done you need to let us know what budget you have left, but probably ~$600. That is going to put you in R5 3600 on a B450, some Ripjaws or similar priced RAM and a half decent ~500W power supply in a modest case. You should be able squeeze a budget SSD/M.2...
You need to check back when your ready to buy. What you can price today has nothing to do with a few months from now.
Reactions: Hellfire13
After that aspect is said and done you need to let us know what budget you have left, but probably ~$600. That is going to put you in R5 3600 on a B450, some Ripjaws or similar priced RAM and a half decent ~500W power supply in a modest case. You should be able squeeze a budget SSD/M.2 solution in there as well.
I apologize in regard to not providing a list. I live US and not really skilled with foreign retailers.
GL
GL
Thanks
Solid build even if over budget. Some solid choices there. Well done, sir.
You could get right at it using a cheaper case and 3600 processor.
PCPartPicker Part List
Type|Item|Price
CPU | AMD Ryzen 5 3600 3.6 GHz 6-Core Processor | £178.99 @ Scan.co.uk
CPU Cooler | ARCTIC Freezer 34 eSports DUO CPU Cooler | £37.27 @ Overclockers.co.uk
Motherboard | MSI B450 TOMAHAWK MAX ATX AM4 Motherboard | £79.99 @ AWD-IT
Memory | Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory | £80.39 @ Amazon UK
Storage | Samsung 870 Evo 1 TB 2.5" Solid State Drive | £97.15 @ Amazon UK
Video Card | Asus GeForce RTX 2060 6 GB DUAL EVO OC Video Card | £399.99 @ AWD-IT
Case | Fractal Design Focus G ATX Mid Tower Case | £40.47 @ Scan.co.uk
Power Supply | Corsair TXM Gold 750 W 80+ Gold Certified Semi-modular ATX Power Supply | £75.98 @ Currys PC World Business
Case Fan | be quiet! Pure Wings 2 51.4 CFM 120 mm Fan | £11.12 @ CCL Computers
| Prices include shipping, taxes, rebates, and discounts |
| Total | £1001.35
| Generated by PCPartPicker 2021-08-11 23:22 BST+0100 |
If it was me I would start trying to find a RTX 3060 or 3060ti now for about the regular price instead of jacked up or a used 2070 / 2070S / 2080.
But as I said their really no telling what you can get for what price a few months from now.
Good price (right now) on the power supply with overkill, not the best quality but you could do a lot worse. DC to DC conversion not the best fan rifled bearing fan about =
sleeve well a bit better on paper made by Great Wall.
Reactions: LeighPing
Type|Item|Price
| Total | £1001.35
I’ve been looking at a lot of 3060ti cards and it’s seems that there is only a couple of models that are in stock my personally choice for a 3060ti would be the MSI gaming x trio 3060 ti from scan as of right now it’s
Type|Item|Price
| Total | £1001.35
ive been looking into 3060ti cards as I do know a fair bit about computers as I have built a few myself but I thought I would get the advice of some more knowledgeable people the 3060 I am thinking of getting is the :
MSI gaming x trio 3060ti
And if this card lowers in price I will have to see whether I am to buy it or not I completely agree with most of the parts in the lists myself and think they were all solid choices
