could the lithium batteries used in EVs be used in place of lead/acid batteries in regular cars?
80251
356
71
18,860
Title says it all. The lithium batteries used in EVs seem to be much more reliable than the lead/acid batteries found in ICE vehicles. Do they have +12V lithium batteries that you could swap for a lead/acid battery? Or would the entire charging system have to be overhauled as well?
Reactions: alizardx
There is a relatively new type of car battery that is replacing the old school lead acid.
AGM - Absorbed Glass-mat
https://www.interstatebatteries.com/blog/what-is-an-agm-battery-and-whats-the-big-deal
My Mini requires one.
Reactions: alizardx and 80251
There are LiFePO4 starting batteries that are drop-in replacements for more common sizes of lead-acid batteries available right now if your car will never encounter freezing temperatures.
Charging a LiFePO4 battery at high speed in subfreezing temperatures will cause immediate damage. All EVs using such batteries have battery heaters and will not allow charging to begin until those batteries have warmed to ~40F. This is why you see all of those news reports of EVs "stranded" at the charger but apparently not charging--all of the charger current is redirected to the heaters and if they had waited long enough before calling the tow truck then charging would've begun.
Dropping a regular LiFePO4 battery into your alternator charged car means either the battery would be destroyed in freezing weather or the battery's BMS would disconnect itself if charging is attempted, which in a modern car would fry all of the car's electronics from voltage spikes (the battery is required to smooth the dirty output of the alternator).
Two battery technologies: Lithium titanate, commonly referred to as LTO (Lithium Titanate Oxide) and Sodium-ion can charge at lower temperatures without damage (to subfreezing -20C or -4F) but are currently about double the cost of present LiFePO4.
AGM lead-acid is not a direct interchange with flooded lead-acid because of different charging setpoints, and normally you have to "register" a AGM battery to the car if it didn't come with one, or do hardware mods. For example it's pretty popular to modify the voltage regulator on Toyota Truck alternators to allow this since AGM is nonspillable (which is why Amazon can ship those but not conventional flooded lead-acid)
There are plenty drop-in replacements already out there. Give google a try.
So basically I can't use either AGM or lithium batteries unless the alternator is designed to work with them?
Is it possible to get aftermarket alternators that work w/AGM or lithium batteries?
I'm tired of replacing lead acid batteries every three years. I'm also tired of having to maintain them (i.e. topping them off w/distilled H2O).
If you live in a place like Hawaii or Florida, then you could just drop a LiFePO4 battery in right now because there is very low risk of cold weather. Otherwise for a motorcycle you could use a surprisingly affordable sodium-ion battery, or if you have deep pockets and need a group 24 battery even a solid state one. But lead-acid performs very well at a good price for starting applications without any deep-cycles--there's a reason EVs come with one lead-acid 12v battery even if they have 480v or more in back.
You can actually just drop an AGM in place of a flooded battery but it may have a lower than expected lifespan due to insufficient charge voltage, unless you get particularly lucky and your car just happens to supply enough (which is a real possibility if you have to top-off a flooded battery frequently) or can be programmed to do so. Otherwise you would add a "diode mod" to adjust the voltage a little.
But that may not be necessary because there are some flooded batteries with the same type of VRLA and venting system as AGM batteries use to prevent water loss. Normal flooded lead-acid batteries have regular caps (which may be hidden under a sticker but are there + vent around the edges), while VRLA are completely sealed/plastic-welded except for a vent tube attached to a labyrinthine maze where water can recombine and be recovered instead of lost. These look exactly like AGM batteries but there may be small clues such as a green Delco eye which reveals it's actually a flooded type. So just look for batteries that do not claim to be AGM yet are clearly impossible to top-up + have a vent attachment for trunk-mounting.
Real AGM batteries of course do deliver more amps (from the greater surface area) + have much higher vibration resistance and don't have shorting problems from shed plate material (both from the fiberglass mat mechanically separating the plates). And seems like a deal at only $20-30 more, but those are for the Calcium-Lead models. If you really want an AGM battery that lasts 10+ years then you have to choose one that advertises 99.99% pure lead to reduce internal corrosion, and those cost more.
Flooded lead-acid often dies from an internal short in one cell. Normal use and especially deep discharges result in shedding of active plate material off--and it doesn't all get recoated back onto the plates when charged. If enough accumulates at the bottom of the cell, then you get a short across and fast self-discharge. Some manufacturers like Exide intentionally do not supply enough free space below the plates so the battery won't last much beyond the warranty period, so instead choose a brand OEMed by Johnson Controls (Clarios/Delphi/Varta) like Walmart's EverStart, or East Penn/Deka.
I don't usually buy AGM unless the car originally came with one, because I replace car batteries every 7-8 years before they go bad to avoid problems, and both cheap AGM and flooded lead-acid last that long for me in a mild climate.
Reactions: 80251
Buy better batteries.
Got a new one for our 2018 Subaru yesterday. 7 year warranty.
And that replaced the original from 2018, so....6-7 years.
And sealed. No adding water.
Reactions: 80251
That's not new, not even relatively. They have been on the market for decades.
Every of those small lead-acids used in UPS units have been AGM and VRLA (== Valve regulated LEad Acid).
AGM is used to shorten average ion path through electrolyte and thus internal resistance, which comes handy for both UPS and cars.
You seem to lack a clue since you obviously consider battery as a black box - you don't care about what's going on inside.
Given that they have their faults, you should.
All of these features come with a price. Closed lead-acid cells are actually VRLA - they have a valve ( small rubber cap on the cell) and they do leak gassess throught heir lifetime. It's just that they leak much less as 98% of the gasses get normally recombined back into the water while still trapped inside glass matrix.
But water still gets lost and there is much less of a reserve and no way to refill it.
Currently, only good answer to lead-acid problem is going to LiFePo4 cells and not faffing around with lead.
Onyl remaing counterargument - cost has literally vanished as LiFePo4 cells are cheap as chips.
Not sure where you're going with this.
My "buy better" was in reply to the OP seemingly having to replace every 2-3 years.
Short answer: no.
Long answer: Lithium batteries require different charging currents/voltages than lead acid. Voltage regulation differs (when to charge) as well.
At a minimum, you would need to change out the alternator. Depending on how the car is set up, you may need to change out the onboard computer as well.
Too expensive to pull off for most automobiles.
EDIT: This is also true for AGM.
If you have more money then you know what to do with, you could get an Antigracity Battery.
From their FAQ's "Our lithium batteries will operate perfectly fine with the stock charging system in most motorcycles, powersports vehicles and automobiles."
Battery for my Jeep is $720-$1050
Battery for my WRX is $950
For what it is, the battery does have some very cool features.
I recall 12V lithium replacements going back as far as the early 2000s. Basically just priced themselves out of the market for the average consumer. They've been hovering around that $1000 mark for a while.
Some newer cars are switching to lithium batteries. Trend started in sports cars and high end luxury cars. The common issue being solved in sports cars is weight, and in luxury cars it is to power accessories and additional security features.
Newer Tesla are adopting a 48v low voltage system, and I expect that trend may continue. Higher voltage allows for smaller wires, which will start becoming an advantage as cars get more and more sensors and features.
I hate to say this, but I just buy Walmart lead acid batteries, they've never really let me down, just replace every 5 years or so. OEM batteries can last a lot longer.
If you are constantly getting dead batteries early, check your alternator output and load, you might need a bigger battery and/or a bigger alternator.
