Question Countless Bsod for months and can't find the exact problem
Dec 4, 2022
15
Hello, I have been struggling with BSOD for around 6 months with no end to this problem. I have taken it to a store and they tested using memtest86 and tested my cpu/gpu and claimed my E: drive was corrupted and that was it. Turned out that fixed nothing and I am still stuck with this problem. Most BSOD mention kernal corruption but I got different ones. Also want to mention that I can't enter bios settings cause I get a black screen if i attempt to. If I do succeed, I have limited time before it freezes there.
Here are my dmp files:
https://files.catbox.moe/aj7b98.dmp
https://files.catbox.moe/rym9kq.dmp
https://files.catbox.moe/r50d65.dmp
My pc:
CPU: AMD Ryzen 5 3600X
GPU: Nvidia GeForce RTX 2060
Motherboard: ASROCK X570 Phantom Gaming 4
Ram: G.Skill F4-3600 16-8GTZNC DDR4 (x2) (Slot 2 and 4 I think )
PSU: EVGA 550W Bronze
Built this pc in 2018
Unless this is part of Ryzen Master, its blind
Mar 11 2020amdgpio2.sysAMD GPIO Controller Driver from Advanced Micro Devices http://support.amd.com/
May 13 2022AMDRyzenMasterDriver.sysAMD Ryzen Master driver
Guess it could be but I would have thought it remove it or even see it.
See if this helps - https://support.microsoft.com/en-us...-removed-cca7d1b6-65a9-3d98-426b-e9f927e1eb4d
Seemed to work on the uninstall and reinstalling part but did not make a difference with Bios View: https://imgur.com/a/dPv8YOv
I even got a black screen with 2 letters (AB) next to eachother for some odd reason
I didn't think updating chipset drivers would help the bios. But I thought it might help the BSOD.
Getting into the bios was another problem that isn't caused by a BSOD.
I wonder if its fact he is running 3600 ram at 3200
8192MB3200MHzUnknownF4-3600C16-8GTZNC
G Skill have tested this ram with board so it should work - https://www.gskill.com/product/165/326/1562840073/F4-3600C16D-16GTZNC but perhaps not at that speed.
could reset CMOS on motherboard (while PC is unplugged) as that will set ram to base speed. And might reduce freezing?
have you tried starting with bare minimum attached?
though to be fair, the only thing you could take out would be 1 stick
Asrock forums are weird, the posts go from bottom of page up. I don't find anything for this board but plenty on freezing Asrock bios.
I've had the speed changed from the default (2333??) to 3600 to 3400 to 3200 and got Bsod on every time. Funny enough yesterday I didn't experience any BSOD until I shut down my pc.
Dump file here:
https://files.catbox.moe/mbusjt.dmp
conversion of dump
report - click run as fiddle to read
File: mbusjt.dmp (Dec 7 2022 - 13:07:45)
BugCheck: [REFERENCE_BY_POINTER (18)]
Probably caused by: memory_corruption (Process: NVIDIA Share.exe)
Uptime: 0 Day(s), 8 Hour(s), 05 Min(s), and 38 Sec(s)
two parts of nvidia as victims of 2 crashes... i might victim blame
try running ddu in safe mdoe, uninstall nvidia drivers, log back into normal mode and get newer drivers from either
  • Maker of card
  • Nvidia
  • Windows update - these are just older more stable nvidia drivers
