I built a desktop with future upgrade of CPU and adding GPU kept in mind with following specs:
For me I first tried to go with air but [150mm cooler max height ] is a issue due to the cabinet. Now I cannot buy both as I'm saving for GPU and CPU. I went to forums looking for cooler within 150mm but those are not available at all in India [ CRYORIG H7, Scythe etc]. So I went both online and offline(in Bangalore,India) to find the cooler which can fit in my case.
Here are some results and I'm having trouble choosing one as of money constraint [want to settle in Rs.4500 / $64 but Rs.5218 / $75 maxed out ] and also I want to select one which will be useful for R5 2600x/ R7 1700 (equivalent in Ryzen 3000 series). I know I might be early asking this but consider it for R5 2600x/ R7 1700 and NOT only for 2200G.
Here are the one's which I shortlisted.
There are some [?] places which I was unable to find data. If you can help me then please do complete it as well. So coming to the question , which one is good to go with ?
Really sorry for the long post but I need some answers.Thank you for being with me till here and thanks in advance for all the answers.
The stock cooler is not working out good. Especially in India where room temp is 26-27C and outside reaching 40+ in summer. So i want to go with aftermarket cooler. There is a long debate which can never end between air and AIO cooler. Most prefer air as to be safe from AIO leaks.But AIO cooler users say that % is very low with current gen.CPU: RYZEN 3 2200G [3.725Ghz/ 1.330 VOLTAGE]
GPU: INTEGRATED VEGA GPU [ 1320MHz ] with 1.22V
RAM: CORSAIR 8GBX2 SINGLE RANK 2933MHz 16-20-20-38 TIMINGS @ 1.35V
SSD: ADATA SU650 480GB
MOTHERBOARD: MSI B450M PRO-VDH
SMPS/PSU: CORSAIR CX450
MONITOR: BENQ GW2280
CABINET: CORSAIR SPEC-04 BLACK (CULPRIT) Max CPU cooler height 150mm
