H HadEnoughOfConsoles Reputable Aug 31, 2014 11 0 4,510 Jun 15, 2015 #1 So I'm gaming on my laptop and I'm getting temperature from 85 - 90 on my cpu and 55 to 63 on gpu, is this normal specs i7 4800MQ cpu and GTX 870M
Solution A A avenseth12 Jun 15, 2015 Your CPU temps seem high, the GPU seems within normal ranges. You may need a USB connected cooler to place underneath your laptop to help cool it. Like this:Cooler Master NotePal X-Slim - Ultra Slim Laptop Cooling Pad with 160 mm Fan $17 http://www.newegg.com/Product/Product.aspx?Item=N82E16834992853&cm_re=laptop_cooling_pad-_-34-992-853-_-Product
A avenseth12 Honorable Jun 9, 2012 2,020 0 12,460 Jun 15, 2015 Solution #2 Your CPU temps seem high, the GPU seems within normal ranges. You may need a USB connected cooler to place underneath your laptop to help cool it. Like this:Cooler Master NotePal X-Slim - Ultra Slim Laptop Cooling Pad with 160 mm Fan $17 http://www.newegg.com/Product/Product.aspx?Item=N82E16834992853&cm_re=laptop_cooling_pad-_-34-992-853-_-Product Upvote 0 Downvote Solution
H HadEnoughOfConsoles Reputable Aug 31, 2014 11 0 4,510 Jun 15, 2015 #3 Thanks for your quick reply and why do you think my cpu temperature is so high Upvote 0 Downvote
A avenseth12 Honorable Jun 9, 2012 2,020 0 12,460 Jun 15, 2015 #4 A CPU running at that level under stress is high. I have an i7 4790k and under stress it doesn't go above 65 C. Upvote 0 Downvote
H HadEnoughOfConsoles Reputable Aug 31, 2014 11 0 4,510 Jun 15, 2015 #5 Laptop are different, but do you think my laptop is broken Upvote 0 Downvote
A avenseth12 Honorable Jun 9, 2012 2,020 0 12,460 Jun 15, 2015 #6 No, I don't think its broken. Just try to cool a little better or you will have problems down the road. Upvote 0 Downvote
H HadEnoughOfConsoles Reputable Aug 31, 2014 11 0 4,510 Jun 15, 2015 #7 while watching youtube videos ar 1080p and searching the net it's at 45 - 50 but when I game it's sky high thanks again for your help Upvote 0 Downvote
H HadEnoughOfConsoles Reputable Aug 31, 2014 11 0 4,510 Jun 17, 2015 #8 Just put my laptop fan on maximum speed and my cpu temperatures is around 74-78 now Upvote 0 Downvote
H HadEnoughOfConsoles Reputable Aug 31, 2014 11 0 4,510 Jun 17, 2015 #9 Is it safe to run it at maximum tho? Upvote 0 Downvote
