CPU and Motherboard Compatibility
cdebi
Hi,
I currently have a Pentium 4 1.5 GHZ ( 400 MHZ System Bus, 256 KB L2 Advanced Transfer Cache, PGA-478) processor. I would like to know if this processor will work with the ASUS P4C800E-DLX Motherboard or will I need a new processor?
Thanks,
Curtis
I believe that chip came in 2 formats. If you have the s423 version, you may be out of luck. I dont know if they make an adaptor, but they may.
If you have the s478 version, according to <A HREF="http://www.asus.com/support/cpusupport/cpusupport.aspx" target="_new">http://www.asus.com/support/cpusupport/cpusupport.aspx</A> you can use it on that mobo.
Looks like it will, since u say it's socket 478.
I went to the asus page linked above and checked.
You can too
The loving are the daring!
