hi there people! i've got a little problem regarding about this system i'm currently using .. the PC suddenly out of power (seems like someone turn off the switch on the power plug, but i'm the only person at home so no way!)
a little history of the way i used before problem occoured : was watching youtube video half way and suddenly power lost , most pc part are about 2 years old, but the GPU i bought it from a reseller and I used for like 7 months.
problem 1 : the moment i press power button on PC the CPU fan spins with led and immediately turn off, but PC case still appeared to have LED on it along with my kb/m LED (with GTX 1070)
problem 2 : take out my current gpu (Zotac GTX 1070), it lights up as for normal but no display or whatsoever
problem 3 : use my old GPU (ASUS GTX 660) it lights up but automatically turns on and off looping every 1 minutes
So i left it untouched with PSU switch off and try again the next day..
problem 4 : PC with GTX 660 able to use as for normal, but when i tried to plug back GTX 1070 it fails to start like in problem 1.
i've done simple diagnose like clear cmos / remove the battery and place it back / switch ram sticks on 4 different DIMM slots but to no avail
note that i also reapplied thermal paste on both GPU and CPU, dust everything clean off too
here are the specs :
Intel i3 6100
Gigabyte GA-B150M-DS3H
Xigmatek X-POWER 500w
ADATA 8GB ram stick
SEAGATE Barracuda 1TB
basic kb/m with LED
Zotac GTX 1070 mini 8GB (has case LED but failed to powered up like usual)
Asus GTX 660 DCU-II 2GB (able to play as normal)
Does anyone has such occurrence before? any experience on it? thanks!
edit : no I didn't overclock my GPU or ram or CPU and i rarely play max settings intensive games and only game on 1080p monitor
Intel i3 6100
ADATA 8GB ram stick
basic kb/m with LED
