Question CPU cooler for an i7 9700k in a corsair air 240 case
Tehflamex
164
Im wondering which CPU cooler would be the best choice for cooling an i7 9700k in my air 240, planning to go to oc to 5 ghz.
build: https://pcpartpicker.com/list/JRmHCb
in addition, i currently have an Master liquid ML120r rgb, cpu AIO cooler, but i dont suppose that'd be nearly enough to cool that CPU :sweatsmile:, i'd also prefer to use an air cooler if possible, but the 120mm high restriction with the air 240 is rather unfortunate.
A 120mm AIO with an overclocked 9700k isn't going to cut it, so yes, you will want a new cooler.
The H100I from Corsair is a good option and PCpartPicker says it will fit. https://pcpartpicker.com/list/DX6Fvn
What is your budget?
130$ give or take some, would it be possible to run it on the 120mm AIO without OC? ( would be cool if i could buy a better cooler later then OC ), do you have any air coolers in mind?
