CPU cooler for Opty 165/ Best stepping?
CallumN
139
Hey, im gonna upgrade from my old socket A athlon 3200+ to a nice dual core Opty 165, on a Asus A8N SLI Deluxe, but whats the best CPU cooler that i can fit in? As in are there any to avoid because of size/placement?
Slightly off topic, what are peoples comments towards using a Thermaltake BigWater SE water cooling kit on an Opteron165? Better for cooling then the new fancy HSF or will it just be an expensive experience with no real benefits?
I have a TT BigWaterSE paid $95 for at Xmas, for my Opteron 175.
I think it is the very best quality and simplist water cooling available for the money.
My CPU under load stays around 41C to 42C
I'm using a Zalman CNPS9500 w/ArticSilver5 on my Opteron165 (gave it's stock cooler to my roommate for his A64 4000+ San Diego). Granted I just built the thing like 3 days ago it's been running idle at about 27C at stock speeds, haven't really stressed it at all yet though.
It's a little ackward to install at first, just make sure you have a decent length screw driver. I like it's little latch piece you screw down, as how it fits on the heatsink it prevents it from sliding up or down once the mobo is in a case. Basically locks it in place vertically (you can still twist it if you wanted too for some reason).
Unlike my Thermaltake Tower 112a I had on my old system, weight about 5lbs and was afriad it was going to slide off the cpu over time so I used a lot of pressured to attach that thing to my 754s I had.
But anyway I hope this helps
what are all the codes about on the Opteron 165? which codes mean what (stepping wise, year, etc) which is the best stepping to get ?
cheers
cheers
Hmmm ya know, correct me if I'm wrong but I don't remember anyone mentioning anything like that in this post?
Perhaps you should create your own? :wink:
cheers
No he raises a good question. Which is the best stepping/core to get?
cheers
Fine ruin my fun 😛
I am curious too about Opty 165 steppings but I think it deserves it's own thread though I'm too lazy atm to make one, hehe :wink:
cheers
Fine ruin my fun 😛
Your curious now you have brought one, didnt you think bout thinking bout it when u made ur new rig.
