Hello all,
Long time reader first time poster. Been looking all over for a solution to this so any advice much appreciated.
I have:
- An X79 Sabertooth mobo in a Fractal Design R3 case (tight fit I know)
- 32GB of Corsair Vengeance RAM (the kind with the obnoxious heat sinks, used for Adobe AE which does indeed eat up that much RAM). I plan to upgrade to 64GB of RAM soon as I'm regularly maxing out the 32 so lets assume all DIMM slots are filled with said RAM.
- Intel 3930K CPU
I'm using a stock cooler that is running too hot for comfort (50c idle) and want to find the best cooler that I can. Ideally to minimally overclock but happy just to have things running cool.
Problem here is that the easy solution via the Corsair H series water coolers will not fit in my case. None of them it seems.
So I am looking for a CPU air cooler that will fit both the tight case and the x79 mobo with all DIMM slots filled with tall RAM.
Any ideas/suggestions MUCH appreciated!
-morg
I have:
- Intel 3930K CPU
-morg
