[SOLVED] Cpu fake thermal throttling
Apr 5, 2019
5
let me start this off by saying i dont 100% know that it is thermal throttling causing the problem but i have tried everything else and this seems to be the most likely problem. A day ago i installed my AMD FX-8350 in my computer and when i booted up csgo i noticed my cpu Clock would go from 4Ghz to 1.36Ghz randomly and this would cause a huge fps drop i have tried setting the core clock in the bios i turned off amd cool n quiet and that seemed to help some but did not solve the problem i checked core temp and it shows my cpu temps at 120 degrees all the way up to 255 degrees which would fry my computer so i think the motherboard heat sensor is broken causing my computer to think it needs to thermal throttle to get the temps back down. is there any way to fix this? Thank you for any help in advance.
